21 years agoNios-II SOPC UART delivers wrong bytes
We use the UART in our Nios-II design that comes with Quartus 5.0SP1 and Nios-II 5.0 We face the problem that sometimes the Uart reports wrong RX Bytes from correct RX streams. The serial str...
21 years agoI'm not sure what you mean by "don't have the source". It's in plain text and all there for you to view, in Verilog or VHDL. It's also the Europa (Perl-based Verilog/VHDL generation) example component (see <nios2_install_dir>/components/altera_avalon_uart/em_uart.pl).....also in plain text.
I haven't looked at the UART or used it very much, so I can't comment on what registers to view. I would definitely recommend re-opening the service request on MySupport, since the response you received was not satisfactory. Best Regards, - slacker
