16 years agoNIOS II software problem
Hi all: I am a new learner of NIOS II. I have a problem about the NIOS II software. When I use the SOPC builder,I found it only has "System Contents" and "System Generation", but no "more CPU ...
16 years agoThank you so much! My software is 7.2, and maybe you did not know my problem at all,because I did not expressed it clear. So I explained it again.
I double click on the "NIOS II processor",and then the CPU set window appears.I can setup the nios cpu,like core, cache, advanced features,.... custom instructions. But when I finish the setting and exit the window,there is not appear a setting tap as "NIOS II More cpu settings" . So that is my problem. I just want to know it is due to the software or my settings.
