MViss4
6 years agoNios II Software Build Tools for Eclipse (Quartus Prime 18.1) frequently crashing
When debugging a project through the "debug" or "run" option eclipse frequently crashes. Find below 2 examples of the screens which appear when eclipse crashes. This is really annoying as you also ma...
TheRealNeil
4 years agoFor any still dealing with this issue, I've found something that helps smooth things out a bit.
Anytime you attempt to debug, and cannot (mine typically will get stuck at 60% when it isn't working) properly launch the sessions, do the following.
Debug > Debug Configurations > Target Connection > Click 'Refresh Connections'
This has shown to be quite helpful. It won't work all of the time, but it will work some of the time!
