13 years agoNios II Software Build Tools for Eclipse - c99 mode
Hi every one! I'm using Quartus 11.0 sp1 and Nios II Software Build Tools for Eclipse with DE2-70 Altera board. How can I configure "mingw nios ii gcc4" in eclipse to use the c99 mode? (I ...
13 years agousing the software build tools eclipse gui
Right Click On Project Folder in the Project Explorer Select Properties Nios II Application Properties User Flags: -std=c99 With software build tools sometimes setting -std=c99 in the GUI doesn't seem to stick :mad:. I never figured out why :confused:. What I did to make it stick was to edit the projects MAKEFILE directly by setting the APP_FLAGS_USER_FLAGS to include -std=c99 .
using the makefile (direct method)
search for app_cflags_user_flags
app_cflags_user_flags := -std=c99
legacy nios ii tools Right Click On Project Folder in the Project Explorer (aka NIOS II C/C++ Projects tab) Select Properties Select The C/C++ Build item Tool Settings Tab NIOS II Compiler-->General Folder Compiler Flags: -std=c99
