12 years agoNios II SBT for Eclipse not working under CentOS 6.5
Recently I had to start working on a workstation with CentOS 6.5 as operating system. I installed the Quartus Software, version 11.1, but the Eclipse tools for Nios II just do not open. Then I instal...
12 years ago --- Quote Start --- Recently I had to start working on a workstation with CentOS 6.5 as operating system. I installed the Quartus Software, version 11.1, but the Eclipse tools for Nios II just do not open. Then I installed Quartus 13.1, but problem still persists. Here is the output I get when executing the eclipse-nios2 -debug command from terminal:
Start VM: /opt/altera/11.1/quartus//linux/jre/bin/java
-Dosgi.requiredJavaVersion=1.5
-XX:MaxPermSize=256m
-Xms40m
-Xmx384m
-jar /opt/altera/11.1/nios2eds/bin/eclipse_nios2//plugins/org.eclipse.equinox.launcher_1.1.0.v20100507.jar
-os linux
-ws gtk
-arch x86
-showsplash
-launcher /opt/altera/11.1/nios2eds/bin/eclipse_nios2/eclipse
-name Eclipse
--launcher.library /opt/altera/11.1/nios2eds/bin/eclipse_nios2//plugins/org.eclipse.equinox.launcher.gtk.linux.x86_1.1.1.R36x_v20100810/eclipse_1309.so
-startup /opt/altera/11.1/nios2eds/bin/eclipse_nios2//plugins/org.eclipse.equinox.launcher_1.1.0.v20100507.jar
-exitdata 4d0054
-product org.eclipse.epp.package.cpp.product
-Debug
-perspective com.altera.sbtgui.ui.cPerspective
-vm /opt/altera/11.1/quartus//linux/jre/bin/java
-vmargs
-Xms40m
-Xmx384m
Install location:
file:/opt/altera/11.1/nios2eds/bin/eclipse_nios2/
Configuration file:
file:/opt/altera/11.1/nios2eds/bin/eclipse_nios2/configuration/config.ini loaded
Configuration location:
Framework located:
file:/opt/altera/11.1/nios2eds/bin/eclipse_nios2/plugins/org.eclipse.osgi_3.6.1.R36x_v20100806.jar
Framework classpath:
Splash location:
/opt/altera/11.1/nios2eds/bin/eclipse_nios2/plugins/org.eclipse.platform_3.6.1.v201009090800/splash.bmp
Debug options:
file:/home/cramos/.options not found
Time to load bundles: 5
Starting application: 1059 After the last line, the application never ever starts. On the other hand, when executing the nios2-ide command, here is what I get: /opt/altera/11.1/nios2eds/bin/nios2-ide: line 17: /opt/altera/11.1/nios2eds/bin/eclipse/nios2-ide: No such file or directory
/opt/altera/11.1/nios2eds/bin/nios2-ide: line 17: exec: /opt/altera/11.1/nios2eds/bin/eclipse/nios2-ide: cannot execute: No such file or directory However, that directory does not exists (I attach an image of the contents of the Nios II directory). https://www.alteraforum.com/forum/attachment.php?attachmentid=8487 I cannot seem to get the Nios II tools running on Linux, and there is no other error message to track down. If further information about the work environment is needed, I will gladly post it here. Any help would be greatly appreciated. Thanks in advance. --- Quote End --- -------------------------------------------------------------------------------------------- Most problems that I hadwith Centos 6.5 linux 64-bit Quartus 12 nios2eds installations are missing 32-bit (i686) libraries... /usr/lib/libmissings ------------------------------------------------------------------------------------- use yum list whatever to see whatever is installed and use yum install whatever-is-missing to install the missing i686 libraries. e.g. yum list glibc libXext libX11 libXau libXdmcp freetype fontconfig expat I did: yum install expat.i686 yum install fontconfig.i686 yum install freetype.i686 yum install libX11.i686 ---------------------------------------------- ok... I saw the Quartus flash screen but sopc-builder can't start:( ---------------------------------------------- For me I ran /opt/altera/12.1/quartus/sopc_builder/bin/sopc_builder to see what 32-bit libraries are missing, I discovered libXtst.so is missing.. so yum again yum install libXtst.i686 ---------------------------------------------- ok... saw the sopc builder flash screen but eclipse can't start :( I got the idea from here: http://aalonso.wordpress.com/2009/07/02/altera-quartus-2-on-fedora-11/ ---------------------------------------------- yum install gtk2.i686 // need for eclipse yum install libcanberra-gtk2.i686 // don't need ---------------------------------------------- ----------- for usb blaster permission create file /etc/udev/rules.d/51-usbblaster.rules with content # USB-Blaster BUS=="usb", SYSFS{idVendor}=="09fb", SYSFS{idProduct}=="6001", MODE="0666" BUS=="usb", SYSFS{idVendor}=="09fb", SYSFS{idProduct}=="6002", MODE="0666" BUS=="usb", SYSFS{idVendor}=="09fb", SYSFS{idProduct}=="6003", MODE="0666" :)
