14 years agoNIOS II SBT Configuration with EPCS Controller
Hi All, I have a basic NIOS II system with a EPCS Controller used for booting. I have successfully flashed the EPCS device and on power-up the FPGA configures and the NIOS boots. However, ...
12 years ago --- Quote Start --- I have now found the final solution to the problem with the run command: There is a parameter in the settings.bsp file, ALT_ALLOW_CODE_AT_RESET, that must be set to 0 in order to get the flash bootloader code to work with the Run command. I have not found how to set this parameter from the BSP-editor, so just edit the bsp file directly. --- Quote End --- Thank you. This resolved a similar issue I was having. I had my reset vector in EPCS flash. I could flash my sof and elf (converted to jic) and run from flash with no problem. However, when I tried to connect with JTAG I would get "Verify failed" at my reset vector offset. Changing ALT_ALLOW_CODE_AT_RESET to zero in my bsp settings resolved this issue for me. I was able to find this setting in the BSP Editor (I am using SBT 12.1sp1). Go to BSP Editor -> Main -> Settings -> Advanced -> hal -> linker -> allow_code_at_reset. Disable checkbox. Hope this helps future users. -JQ
