14 years agoNIOS II SBT Configuration with EPCS Controller
Hi All, I have a basic NIOS II system with a EPCS Controller used for booting. I have successfully flashed the EPCS device and on power-up the FPGA configures and the NIOS boots. However, ...
14 years agoAre you sure the Nios II instruction master is connected to the EPCS controller and not just tho data mastor? If you don't see the controller in the reset menu it means there is a problem with the way all the components are connected, or at least in how SOPC builder / QSys sees those connections.
