14 years agoNIOS II SBT Configuration with EPCS Controller
Hi All, I have a basic NIOS II system with a EPCS Controller used for booting. I have successfully flashed the EPCS device and on power-up the FPGA configures and the NIOS boots. However, ...
14 years agoI built (and patched) the compiler, and use vi + make and my own scripts.
Not tried to build it for cygwin on windows - but will probably build ok. It reality for a release build you need scripts, not a gui - otherwise you can't reproduce and automate things very easily. The code we use is loaded via the PCIe slave interface from a ppc (running linux). I actually extract the nios code+data, convert them to ppc .o, and link into the ppc binary - then link the ppc binary with the nios symbol table! This guarantees the two parts match. No IDE is going to support that sequence! I need two different cross compilers on the build system.
