Michael-C
2 years agoNios-II Resets with PIO command
I am developing an application using the Nios-II embedded CPU. It utilizes multiple PIO ports, configured as inputs and outputs. I have one in particular that is being very troublesome. Everytime I w...
wwanalim_intel
Contributor
2 years agoHi,
I am checking all the pin is correctly used for the SolA and SolB. Can you explain more on SolA and SolB.
- Michael-C2 years ago
The GPIO SolA and SolB drive banks of solid state relays, PGV612A, to toggle a +24V off board signal to drive solenoids (22 in total).
The anode of the relay is tied to the +5v supply rail. The cathode of the relay is tied to the GPIO through a series resistor. The GPIO toggles between tri-state and logic 0 and is set to LVTTL in the FPGA.
