20 years agoNIOS II reset
Dear everybody, My goal is to reset NIOS II. NIOS II owns the reset_n input and I drive this input with a signal ON-OFF-ON where the OFF state lasts 20 us with the clk signal always present...
20 years agoAlessandro:
I am having the exact same problem. I have the the SOPC system, a PCI-X bridge, and several other components. I need to reset everything on a PCI reset, or reset the SOPC system and several components when I get a specific message from the PCI-X. I have tried making the reset as long as a second, or as short as less than one microsecond. The result is always the same--the NIOS II refuses to start afterwards. The strange thing is: when I get a PCI reset (resetting everything) it works fine. The NIOS II is booting from internal memory. Let me know if you find a solution.
