21 years agonios II on old dev kit
Hello I purchased a Nios Development Kit Cyclone Edition about a year ago. The board was delivered with the Nios processor 3.1. Can I use NIOS II on this board? The board specs seem to be ident...
21 years ago<div class='quotetop'>QUOTE </div>
--- Quote Start --- The board specs seem to be identical with the current version that comes with the NIOS II dev kit.[/b] --- Quote End --- To confirm what you suspect, when the device is the same, the Nios II dev. kit uses the same board as the older Nios dev. kit. Just the MAX device and the Flash device are programmed differently. (Gotta love that programmable logic: same board, two different products.) Kerry Altera
