21 years agonios II on old dev kit
Hello I purchased a Nios Development Kit Cyclone Edition about a year ago. The board was delivered with the Nios processor 3.1. Can I use NIOS II on this board? The board specs seem to be ident...
21 years ago> There seems to be a problem with the LCD.
I can't comment on this ... I never use the LCD. > If I renew my subscription I suppose I won't get the USB blaster <...> When I renewed/upgraded my subscription as a devkit customer, I was able to upgrade to USB Blaster at no cost (other than shipping). I'm not sure if this offer is still available ... you might want to check with your sales rep. > <...> which seems to be the only supported communication device for NIOS II. I continue to use ByteBlaster for most of my work without any trouble. Although I normally use a serial uart for the console. I've had trouble using ByteBlaster when using the JTAG uart. When I _need_ to use the JTAG uart, which is rare in my particular case, I use USB Blaster -- and everything works fine :-) Regards, --Scott
