22 years agoNios II on HC device
Hi all,
It seems that Nios II use *.mif file to initialize cache tag memory. We can find "dc_tag_ram.mif" and "ic_tag_mem.mif" file in project directry. Cache tag is RAM, so I think this means Nios II need pre-loaded RAM feature. Other side, HardCopy device does not support pre-loaded RAM feature, I heard. If cache tag contents are un-defined at reset time, I think Nios II does not run correctly. But Altera says Nios II support HC Device. What is wrong in my thinking? Thanks4 Replies
There is an open problem report on this. It's being worked on.
If you have a Nios II design that you need to go to HC with now, please email me off line. - Altera_Forum
Thank you, Kerri.
This question is just only my interest. I wait the future release. Could you describe how to avoid this problem in the future release? (If that's not a confidential information.) - Altera_Forum
The MIF files for the cache contain random values to make the FPGA RAMs behave like uninitialized
hardcopy RAMs. I did this so that we could be confident that the caches would work properly on hardcopy. BTW, the register file RAMs also have MIF files that initilalize all registers to the value 0xdeadbeef including register 0. The reset logic sets register 0 to zero as is required for correct operation. Once again, this works properly on FPGA or hardcopy devices. The optional debug core features do rely on initialized RAMs for the Nios II 1.0 release. A future release of Nios II could allow the debug core to work on hardcopy but this wasn't considered critical for the 1.0 release. Maybe this is what Kerri was alluding to in her response. We don't expect many customers to put the debug core on their hardcopy devices because they don't want the overhead of it and should have already debugged their system using an FPGA. So, the Nios II CPU will work for our hardcopy customers. This is a strong requirement because we believe Nios II on hardcopy will be a popular option. - Altera_Forum
James, Thank you for description.
I did not know that cache tag value are random. But.. for example. If the debuging core could not be on HC device, I think there is no way to write external Flash via JTAG. My understanding is Flash Programmer needs this core. Anyway, I see that the future virsion of Nios II will support HC. That's good news. Thanks all.
