22 years agoNios II, nonblocking i/o, anyone
Does anyone know how to implement a nonblocking input function on the jtag uart on NiosII ? On Nios I used nr_rxchar(), which returns even if there is no character waiting. The suggested r...
22 years agoHi NiosII users,
I also need a nonblocking uart read, but I am having some trouble with the defined switches. // if I open a stream in this way: fp = fopen("/dev/uart1","r+"); //then fread(buff,sizeof(char),1,fp); // it works OK but blocks until a character is available. // but if I use the defined switch (from fcntl.h) fp = fopen("/dev/uart1","O_RDWR"); // it dosnt read or write! I wish to use: fp = fopen("/dev/uart1","O_RDWR|O_NONBLOCK"); By the way, the second argument to fopen should be of type 'const char*' (eg. "O_RDWR|O_NONBLOCK"), no t an integer produced by: O_RDWR|O_NONBLOCK fp = fopen("/dev/uart1",O_RDWR); The above line will compile with a (implicit cast) warning, but should not give correct operation. Any ideas?
