Devin2
2 years agoNIOS II Memory Initialization File Depth
Hello, I have software written in C in Nios II to be combined with some hardware design done in Quartus. I generated a memory initialization file (.hex) through the "Make Targets" tool in my Nios pro...
Devin2
2 years agoI've attached the requested screenshots. The error message may be tough to read in the photos, it says "18094 Memory depth (122464) in the Memory Initialization file 'C:/Users/ removed for privacy purposes /mem_init/onchip_flash.hex' is less than the flash memory depth (45872). Make sure the Memory Initialization File contains the sufficient memory depth values for the flash memory." Also, in the platform designer screenshot there are a few more fields when you scroll to the right but they are all empty for the onchip_flash IP.
