21 years agoNios II Linux v1.4 does not support CycloneII?
Does Nios II Linux v1.4 not support CycloneII (EP2C35F672C6)? How can I port uclinux in my CycloneII? Please give me some suggests.
21 years agoDoug: We've had read-back problems from memory on boards other than the CycloneII (we don't have one in house yet). In our case, we've narrowed it down to the data cache line sizes... for some reason, we can't run Linux reliably on a system with a data cache line size greater than 4 bytes. I'm wondering if you're running into a similar problem?
weichuan: Not a problem... but I need more information. Telling me that it still doesn't work isn't all that helpful. Can you send me the following files via pm? <kernel project>/build/arch/nios2nommu/hardware.mk <kernel project>/build/.config Did you get past the configuration process? Were you building? Did it fail during building? If so, maybe you can also send me the last 50 some odd lines of output from the build process.
