22 years agoNios II LCD Driver
Greetings. Quite simply my LCD doesn't "work" with Nios II. It has and does work with Nios I. From the simple "web server" default reference design where the display should show something...
22 years agoQuan,
I have included the pin list that I have cut-and-pasted out of my Assignment Editor.Proto2_LCD Location PIN_U10
Proto2_LCD Location PIN_V10
Proto2_LCD Location PIN_W10
Proto2_LCD Location PIN_Y10
Proto2_LCD Location PIN_V11
Proto2_LCD Location PIN_U11
Proto2_LCD Location PIN_W11
Proto2_LCD Location PIN_Y11
Proto2_LCD_E Location PIN_T10
Proto2_LCD_RS Location PIN_Y9
Proto2_LCD_RW Location PIN_W9 As you can see, I used the same pin names as the reference design, but prefixed each name with Proto2_ <div class='quotetop'>QUOTE </div> --- Quote Start --- You mentioned moving the LCD from PROTO1 J10 to PROTO2 J15, on my board the lcd is attached to the PROTO1 J12. Also I forgot to mention i am using the Cyclone dev kit from Altera.[/b] --- Quote End --- I too am using the Altera Cyclone dev kit, and I meant proto1, J12. Sorry for the confusion. Regards, -Terry
