22 years agoNios II LCD Driver
Greetings. Quite simply my LCD doesn't "work" with Nios II. It has and does work with Nios I. From the simple "web server" default reference design where the display should show something...
22 years ago --- Quote Start --- originally posted by tjd@Jul 15 2004, 01:08 PM kerri,
i recently took the full_featured ref design and moved the lcd from proto1 j10 to proto2 j15.
if anyone would like me to send you the updated pinout list, let me know. really all it took was a quick look at the schematic to ensure the proper pinout was applied.
the lcd now works properly, and i can talk to my cf device.
regards,
-terry --- Quote End --- Hi Terry, I would like to see the updated pin file if you don't mind posting it or email it to me. My situation will be a bit different in that I will need to share the pins like in the old nios configuration. I have built a daughter board to attach to use the PROTO2 pins and so i won't be able to relocate to any of the PROTO2 pins. I'm looking through and comparing the old lcd driver with the newer ones and trying to see if I can reach a happy medium. Actually come to think of it, i wonder if the hardware was changed? You mentioned moving the LCD from PROTO1 J10 to PROTO2 J15, on my board the lcd is attached to the PROTO1 J12. Also I forgot to mention i am using the Cyclone dev kit from Altera. -Quan
