22 years agoNios II LCD Driver
Greetings. Quite simply my LCD doesn't "work" with Nios II. It has and does work with Nios I. From the simple "web server" default reference design where the display should show something...
22 years agoHi Terry,
Which ref design are you using that has these CF_CS_N and CF_POWER signals already labelled? In the older nios I, these are part of the standard ref design. I can toggle the CF_POWER lines to re-initialize the cf when needed, but in all of these new nios II ref designs, these signal lines do not exist in the bdf file. as a matter of fact, i was not able to find any ref design that contains any available lines for the usage of the compact flash. i wonder why? -Quan
