22 years agoNios II LCD Driver
Greetings. Quite simply my LCD doesn't "work" with Nios II. It has and does work with Nios I. From the simple "web server" default reference design where the display should show something...
22 years agoUPDATE:
It appears as though I have a work-around to the LCD errata that was discovered previously in this post re: <div class='quotetop'>QUOTE </div> --- Quote Start --- The LCD will not operate if the Compact Flash card is plugged in[/b] --- Quote End --- I have the LCD now working with the CF card plugged in to the devkit... Here's how: I tied the internal I/O pins: CF_CS_N to Vcc to disable the Compact Flash chip select and set CF_POWER to GND to disable power to the CF interface... Note that if you want to talk to the CF card, you will have to enable both the CS and CF_POWER signals; thus running into the same problem as before... (or so it seems). temp fix anyways. -Terry
