22 years agoNios II LCD Driver
Greetings. Quite simply my LCD doesn't "work" with Nios II. It has and does work with Nios I. From the simple "web server" default reference design where the display should show something...
22 years agoHi Terry,
I haven't tried the full_featured ref design of the nios II yet. I am still only using the nios I but if these are problems not cannot be fixed yet, then i will not do the full upgrade path. There is the legacy upgrade path to enter into the nios II realm, I wonder if the legacy lcd drivers will still work with the nios II? I'll have to try it in the next couple of weeks. Please update if you find a fix on this, and i will do the same. thanx, -Quan
