22 years agoNios II LCD Driver
Greetings. Quite simply my LCD doesn't "work" with Nios II. It has and does work with Nios I. From the simple "web server" default reference design where the display should show something...
22 years agoStrictly an FYI, re:
<div class='quotetop'>QUOTE </div> --- Quote Start --- I tried to make a change but got hung up on a problem with downloading my ref design. It seems that I can't mod the full_featured ref design and successfully download it. I suspect this is a silly bug on my part that I haven't had time to look further into... Side note: Has anyone else experienced this?[/b] --- Quote End --- Turns the PC I am using isn't properly licensed for Nios/Nios II. As a result, I needed to program with the full_featured_time_limited.sof rather than the full_featured.sof file. I will advise if/when I make headway. Cheers, -Terry
