22 years agoNios II LCD Driver
Greetings. Quite simply my LCD doesn't "work" with Nios II. It has and does work with Nios I. From the simple "web server" default reference design where the display should show something...
22 years agohi tjd,
Sorry to bring this topic back up. But the work around you came up with, did it work with the compact flash card inserted in the dev kit? My design involves using a compact flash card to store data which is then fed into the sdram. I am trying to upgrade to a nios2 system right now, but if I cannot use the lcd with the cf card inserted, it might pose a problem. The design i have currently can be used as a stand alone product or attached to a pc, but requires the lcd in stand alone mode. thanx, -Quan
