22 years agoNios II LCD Driver
Greetings. Quite simply my LCD doesn't "work" with Nios II. It has and does work with Nios I. From the simple "web server" default reference design where the display should show something...
22 years agoHave you got the compact flash card plugged in? It doesn't work with Nios II if the compact flash card is plugged in, this is barely mentioned in a readme text file somewhere!
Adrian
