20 years agoNIOS II JTAG Download errors
Well, Im' experiencing the same problem many others have... Trying to bring up a new custom board. Using cable "USB-Blaster [USB-0]", device 1, instance 0x00 Pausing target processor: not...
20 years ago --- Quote Start --- originally posted by jdhar@Feb 5 2006, 09:51 AM well, im' experiencing the same problem many others have... trying to bring up a new custom board.
<div align='right'><{post_snapback}> (index.php?act=findpost&pid=12552)
--- quote end ---
--- Quote End --- Hey, So we're having almost the same issue, with one difference. We've narrowed it down to an SDRAM issue. I noticed that you said you set your sys libraries to use on chip RAM. We did that, and it worked; whereas it wouldn't work if we used SDRAM. Then we ran a memtest on the SDRAM, and I'm getting sort of intermittent errors on just a walking-ones check on a single address line. I mention it here because I'm not sure exactly where to go with this. The data we get back is weird, I'll show you what I mean. It doesn't seem to be a stuck bit or stuck data line, because the behavior is not consistent. Here's the output of the memory test I wrote (which is basically the memtest project in the IDE): -Data Bus Error: Expected 0x00000001, got 0xA001F981 -Data Bus Error: Expected 0x00000002, got 0x8000FD82 -Data Bus Error: Expected 0x00000004, got 0x0000F304 -Data Bus Error: Expected 0x00000008, got 0x0000E908 -Data Bus Error: Expected 0x00000010, got 0x00008110 -Data Bus Error: Expected 0x00000020, got 0x00000120 -Data Bus Error: Expected 0x00000100, got 0x00000000 -Data Bus Error: Expected 0x00004000, got 0x00000000 -Data Bus Error: Expected 0x00008000, got 0x00000000 The omitted patterns have been written and read properly. Running it again will get ALMOST the same errors, for example, a few ones had changed to zeroes and vice versa, or a different pattern will cause error. I don't understand how the same address could get written as 0xA001F981 from a walking-ones pattern. I guess there's some problem with our timing, but I'm not sure how to debug it effectively. Our only idea now is to run a looping write to a single address with constant data, go through each pin on our board, and compare the result on the oscope with what we expect. Anyway, I posted this here because you seem to have a bit more experience debugging this sort of issue, I thought you might have some other ideas. Thanks.
