22 years agoNIOS II ISS Simulator error
Hi all, I'm getting this error when running a simple application: the application works fine; at a given point I need to change the stack pointer to another (fresh, never used) location. ...
22 years agoI wouldn't characterize the ISS as being over cautious at all. One of the main benefits of running on a simulator is that it can easily catch this sort of error in you code. It can be very hard to find these sort of errors when running on real hardware: the uninitialized value might not cause a problem most of the time (but it surely will during product demos!).
If your code is reading values off the stack that it hasn't set, it could potentially signal a problem (unless, as in this trivial case, you don't actually use the data).
