21 years agonios II implementation problem
Respected members, I have some doubts on Nios II processors. I am requesting the forum members to clarify my doubt. When designing NiosII processor system using SOPC builder, there is a on...
21 years agoI forget what 8051 code looks like, however the porting of the C code will mainly require changes to how you access peripherals, and whether or not your code was very dependent on what was previously available. So my answer is yes, but depending on the code it could be a simple or complex job. If the 8051 was memory mapped I/O (can't remember myself) then the port will not be too bad, and if this is not the case then some re-structuring may be needed (again it really depends on the code to be ported).
What does the 8051 in the system do? Also you may find that you just want to port the functionality and redo the code (might be more efficient the 2nd time around).
