14 years agoNios II IDE
Sir, i hv created a SOPC design using nios II (s) , jtag, sdram,pio,timer,sysid using Quartus 7.2 and trying to run hello program on this design using Nios IDE 7.2 . Build is successful, however ...
14 years agoHi,
please try to provide more detailed description of what your doing. So let me assume that your JTAG-Adapter wasn't able to find your HW. Clcik on run and open your Run Configurations... Under NIOS II Hardware there should be your device listet, choose it and change to tab Target connection, there should now be your jatag adapter visible under Processors and Byte Stream Device, if not click on refrech connections. Good luck
