14 years agoNios II IDE
Sir, i hv created a SOPC design using nios II (s) , jtag, sdram,pio,timer,sysid using Quartus 7.2 and trying to run hello program on this design using Nios IDE 7.2 . Build is successful, however ...
14 years agoSir,
Thanks for the help. I will be extending the same design for the RTOS ( ucos ) and then building application layer using TCP/Ip stack of the ucos. This application layer I will used to query the Tripple Speed Ethernet design I have build. I hope u will support for this work also. Regards RSG
