14 years agoNios II IDE
Sir, i hv created a SOPC design using nios II (s) , jtag, sdram,pio,timer,sysid using Quartus 7.2 and trying to run hello program on this design using Nios IDE 7.2 . Build is successful, however ...
14 years agoHi there,
okay first lets see if your debugger is recognized, but must be if you were able to download the sof file. In Nios-IDE choose the menu Run and click on "RunConfiguation" There should be a poitn Nios II Hardware and in best case an existing configuration, otherwise create one. When you click on your configuration and then on the tab "Target connection", there you should see your debugger.
