19 years agoNIOS II IDE
I need information on where I can find the Macros which are to be used to access the registers in peripheral devices. Any help is appreciated
19 years agoThanks, I found all types of configurations I had done in that list on the right hand side.
I want to use the on chip memory in my design. So, Do I just address the memory by looking at the address in the memory map? or do I have to look for some readymade function to write in that memory for me... Thanks a lot --- Quote Start --- originally posted by slacker@Jan 30 2007, 05:38 PM the ide should be able to tell you where any header file is coming from, by clicking on the element in the right hand side column.
however, there's also a simple convention that is used for all avalon components. the header file, you're looking for is defined in the the <component_dir>/inc/<component_dir>.h file.
the generated_all.mk file (in the system_description directory of your system library) will tell you the specific paths to hunt down....though, like i say in the first statement, the ide should be intelligent enough to figure this out for you....should being the operative word!
cheers,
- slacker
<div align='right'><{post_snapback}> (index.php?act=findpost&pid=21042)
--- quote end ---
--- Quote End ---
