19 years agoNIOS II IDE
I tried downloading different example configuration examples from Altera, but I always get the following error. I also once tried to let the 'cheatsheet' perform all the sheets but I still go...
19 years ago --- Quote Start --- originally posted by tux.2000+jan 24 2007, 12:11 pm--><div class='quotetop'>quote (tux.2000 @ jan 24 2007, 12:11 pm)</div>
--- quote start ---
--- quote start ---
originally posted by napster@jan 13 2007, 04:40 pm
--- quote start ---
originally posted by liuliqiang@jan 13 2007, 08:12 am
<!--quotebegin-napster@Jan 12 2007, 03:13 PM i tried downloading different example configuration examples from altera, but i always get the following error. i also once tried to let the 'cheatsheet' perform all the sheets but i still got the same error. please help!!! i don't understand what is happening ....
i am trying to download the hello_world program.
using cable "usb-blaster [usb-0]", device 1, instance 0x00
pausing target processor: not responding.
resetting and trying again: failed
leaving target processor paused
<div align='right'><{post_snapback}> (index.php?act=findpost&pid=20540)
--- quote end ---
--- Quote End --- it may be your pins assign error in quartus top-level design.or there is a incorrect config commponent in sopc builder <div align='right'><{post_snapback}> (index.php?act=findpost&pid=20557)</div> [/b] --- Quote End --- Thanks it worked ... <div align='right'><{post_snapback}> (index.php?act=findpost&pid=20560)</div> [/b] --- Quote End --- What is the solution for this problem??? <div align='right'><{post_snapback}> (index.php?act=findpost&pid=20827)</div> [/b] --- Quote End --- The most common reason that leads to this is 1. incorrect pin assignment (forget to import the pin assignment) 2. miss-matched sopc builder file and actually sof file (forget to download the new sof file to the FPGA). So you can check these two places first.
