21 years agonios II IDE problems
Iam facing a problem with the Nios II IDE. After generating the system on SOPC Builder and then running c/c++ application programs in the IDE iam getting the following error: " The image on...
21 years agoIf you want to use this feature you can include the system ID component with your system (it's very small). That way if you happen to change something in your system you will get a warning telling you that your software may not run properly (handy if you make a lot of changes).
If you are the careful type however then just turn it off (that's what I do).
