16 years agoNIOS II IDE Error 2 on Hello World
I seem to be having a weird error with the NIOS II IDE 9.0. When I try to build/run the hello world example, I get this: **** Build of configuration Debug for project hello_world_0 ****
make ...
16 years agoHow i see you didn't build your project. See on the first code example, you have two errors. In the NIOSII IDE click on "problems" tab(it's located above the message "Build completed in 11.295s"). When you click that tab you will se log errors. Send that if you can't solve your problem.
