21 years agoNios II IDE 5.0 run-option
In NIOS II 1.1 I frequently use the option to disable to build a project before running it. I did this because I had to load the design very often and saved time because the IDE doesn't check if it needs to build the project again. It is the option in the run dialog screen "Build project and dependents (if required) before launching" But in NIOS II 5.0 this option is removed, does anybody know if it still exists? Maybe in another menu or screen? Thanks in advance. JMastron.2 Replies
I think what you are looking for can be found in:
Window->Preferences->Run/Debug->Launching - Altera_Forum
Hi Cliff,
thanks! http://forum.niosforum.com/work2/style_emoticons/<#EMO_DIR#>/smile.gif
