16 years agoNIOS II hex-File for On-Chip_Mem
Hello, i am using an NIOS II /e Core with a On-Chip Memory. The .hex-File is generated using the Make_mem_init_install of the Eclipse IDE. After creating the hex-File i select "Update mif-F...
16 years agoYeah that's definitely not correct.
Inside your BSP directory there should be a mem_init.mk file. Can you attach that? Also, you may want to look at the console in the IDE when you run the make mem_init_install and see what is actually being executed. Jake
