16 years agoNIOS II hex-File for On-Chip_Mem
Hello, i am using an NIOS II /e Core with a On-Chip Memory. The .hex-File is generated using the Make_mem_init_install of the Eclipse IDE. After creating the hex-File i select "Update mif-F...
16 years agohow you creating HEX file? manually? I do no use Eclipse mode, but using NIOS IDE onchip_mem.hex file is created automatically in the same work directory where other project files are placed.
