20 years agoNios II hardware downloading
Hi all. When i running my code , i see in terminal window next rows: Using cable "ByteBlasterII [LPT1]", device 1, instance 0x00 Pausing target processor: OK Reading System ID at addre...
20 years ago --- Quote Start --- originally posted by burdalex@Nov 23 2005, 12:27 AM hi all.
when i running my code , i see in terminal window next rows:
using cable "byteblasterii [lpt1]", device 1, instance 0x00 -->you are using a byteblaster ii cable on your first parallel port, connecting to the first device in the jtag chain, and the first instance of an oci core attached to device 1
pausing target processor: ok -->was able to communicate with the processor properly
reading system id at address 0x00930820: verified -->the system id peripheral value matches the expected value
downloading 00900020 ( 0%) -->downloading contents starting at 0x00900020 (probably the exception address you set in sopc builder)
downloading 01000000 ( 0%) -->downloading more contents starting at 0x01000000 (the rest of the code)
downloaded 64kb in 1.6s (40.0kb/s) -->confirmation that all contents were downloaded (64kb) in 1.6 seconds at a rate of approximately 40kb/s
verifying 00900020 ( 0%)
verifying 01000000 ( 0%)
verified ok -->verifies everything that was downloaded and it passed
please, tall me what every row means.
thanks at advance.
alex
-->so it looks like you had a sucessful software programming http://forum.niosforum.com/work2/style_emoticons/<#emo_dir#>/rolleyes.gif
<div align='right'><{post_snapback}> (index.php?act=findpost&pid=11104)
--- quote end ---
--- Quote End ---
