21 years agoNIOS II hangs when switching to onchip memory
Hi, I've trouble moving from a NIOS II system with flash and external SRAM to a self contained system runnning with onchip memory only. We need this for programming our flash the very first...
21 years agoThank you all for your suggestions.
With your input I reduced the code footprint down to 23k, which fits into the 24k of on chip memory. However, still there's no function, the NIOS hangs when calling "alt_flash_open_dev". I tried to reproduce this simulating the NIOS in modelsim and found out that the NIOS hangs when calling strlen from within "alt_flash_open_dev", but only if the read-only data memory is set to onchip memory. Setting the read-only data memory to external SRAM it behaves fine in modelsim, but in reality there's still no function. BTW: is it legal to set the read-only section to not initialÃzable external memory? Does the startup code handle the initialisation?
