21 years agoNIOS II HAL question on memory size
Looking in system.h, I see the define for SDRAM_BASE. There is no define, tho, for the size of SDRAM. In the old excalibur.h, there was a define for the base, end, and size. There used to be a na...
21 years agoThe linker file is autogenerated, you can find it in the syslib dirs (AFAIR it's called generated.x). You can access these symbols from your code.
Dirk
