21 years agoNIOS II HAL question on memory size
Looking in system.h, I see the define for SDRAM_BASE. There is no define, tho, for the size of SDRAM. In the old excalibur.h, there was a define for the base, end, and size. There used to be a na...
21 years agoThanks for the info, but I am a little lost. I cannot get my application I am porting from Nios to Nios II to build because all the changes. What is the extension of the linker file (.lnk?)? If it will not build, will it create the linker file?
thanx
