17 years agoNIOS II HAL problem
Is there possibility to avoid using HAL ? I started a new design in NIOS IDE and program, which does nothing (empty, endless loop) uses 13 kB of memory, and I have only 20 kB of Memory. I'm using the...
17 years agoThank you for advice, but code size reduction is insufficient. Can I not use HAL and write device drivers on my own ?
