fpgaSoft's avatar
fpgaSoft
3 years ago
NIOS II Generic Serial Flash IP
I am trying to interface to the onboard configuration Flash on a Cyclone 10GX dev kit via NIOS II.
The dev. kits uses a EPCQL1024F24IN device
The Generic Serial flash interface IP has been setup in the platform designer.
Currently all I am trying to do is read the Device ID.
When reading the ID all I get back is 0xffffffff.
I have tried an oscilloscope on the clock line of the dev kit (R655), and it does not change at all. A clock can be seen on this line however when programming the kit via Quartus programmer.
Inorder to do more testing I changed the IP to output SPI pins, and I joined them to the U58 on the dev kit, namely a IS25WP256D-RHLE device.
Using the same code as before, the device ID is read properly.
Presumably I am doing something wrong somewhere , any suggestions at all?
Many thanks
  • KellyJialin_Goh's avatar
    KellyJialin_Goh
    I’m glad that your question has been addressed, I now transition this thread to community support. If you have a new question, Please login to ‘https://supporttickets.intel.com’, view details of the desire request, and post a feed/response within the next 15 days to allow me to continue to support you. After 15 days, this thread will be transitioned to community support. The community users will be able to help you on your follow-up questions.
    Thank you.
    Kelly Jialin, GOH
