fpgaSoft
3 years agoNIOS II Generic Serial Flash IP
I am trying to interface to the onboard configuration Flash on a Cyclone 10GX dev kit via NIOS II. The dev. kits uses a EPCQL1024F24IN device The Generic Serial flash interface IP has been setup in...
KellyJialin_Goh
3 years agoHi,
Are there any further support needed from my end?
I would be happy to dig in deeper regarding your questions.
Thank you.
Kelly
fpgaSoft
3 years agoHi Kelly,
yes more support is required please.
I need to be able to talk to the EPCQL config device, an example project that actually works on the GX10 dev kit would be good. Without the ability to talk to the config flash then my project is effectively dead.
Best Regards
