fpgaSoft
3 years agoNIOS II Generic Serial Flash IP
I am trying to interface to the onboard configuration Flash on a Cyclone 10GX dev kit via NIOS II. The dev. kits uses a EPCQL1024F24IN device The Generic Serial flash interface IP has been setup in...
KellyJialin_Goh
3 years agoHi,
Greetings and welcome to Intel's forum.
The flash device in your devkit (EPCQL) no longer supports the GSFI IP that's why u are unable to read the device ID.
However, you may have a look for an alternative workaround of replacing the EPCQ flash to Micron MT25Q device for your reference here: https://www.intel.com/content/www/us/en/support/programmable/articles/000076544.html?cq_ck=1522223941654
Thank you.
Kelly Jialin, GOH
fpgaSoft
3 years agoHi,
even if the IP does not support the EPCQL devices, why is there no data or clock on the lines to the device?
many thanks
