12 years agoNios II Gen2 core error
I just migrated my nios II to Nios II Gen2 core. I got a error as below. i tried to set instruction and data cache size to none. still give same error. /HAL/src/alt_remap_uncached.c:52: warning...
11 years agoI'm pretty sure you can still use the high address bit to request uncached accesses.
You also have to option of using the full 32bit address range and marking a smaller amount uncached (probably the very top). There is a subtle difference in that writes with the high address bit set will no longer update any resident cache line - so if such a line exists, then when it is written back, the contents will be wrong. Any sensible code won't be doing that anyway, writes by the hardware/dma have always got lost if there was a cache line. OTOH if you use alt_remap_uncached() on buffers returned by malloc (etc) then you deserve what you get. Get the linker script to assign the DPR area address with the high bit set.
