21 years agoNios II Flash Programmer vagueness
I have a Nios II project I'm trying to download using the flash programmer, and it gives me this vague error message: "There is a problem with the target board. Check the target board selection ...
21 years agoI use NIOS 1.1 and have the same problem, even more if it finds the sof file
it generates a wrong flash programmer script. Therefore I use the nios sdk shell (bash) and a own written script file for the flash programmer. There you can tell the flash programmer the correct path to your board.file. This works fine.
