21 years agoNios II Flash Programmer vagueness
I have a Nios II project I'm trying to download using the flash programmer, and it gives me this vague error message: "There is a problem with the target board. Check the target board selection ...
21 years agoMike DeSimone,
<div class='quotetop'>QUOTE </div> --- Quote Start --- "There is a problem with the target board. Check the target board selection in SOPC Builder for this system."[/b] --- Quote End --- Try the following: - Open NIOS IDE - Open Quartus - Open SOPC Builder - Close SOPC Builder - Run Flash Programmer You can use 'Flash Programmer' now only once. Everytime you restart it, SOPC-builder must be reopened (and 'javaw.exe' started). If your system then slows down: - Close IDE - kill process: javaw.exe - Restart IDE - Open NIOS IDE ........ ........ its that easy ... http://forum.niosforum.com/work2/style_emoticons/<#EMO_DIR#>/dry.gif Mike
