20 years ago
NIOS II Evaluation Kit problem
One year ago, I have bought the NIOS II Evaluation Kit.
And I try to use it now :-)
I try to create a C++ project, when I compile it seems good but when communicating with the devboard there is this problem :
I used :
NIOS II Evaluation Kit 1.1
Quartus II 4.2 Web Edition Full
Using cable "Nios II Evaluation Board [USB-0]", device 1, instance 0x00
Pausing target processor: OK
Reading System ID at address 0x021208B8: does not match
ID value does not match: read 0x14400B2E; expected 0x2FF81C2D
Timestamp value does not match: image on board is newer than expected
Read timestamp 13:10:34 1906/03/20; expected 9:45:02 2004/11/25
The software you are downloading may not run on the system which is currently
configured into the device. Please download the correct SOF or recompile.
Restarting target processor# #############################
For me, the problem comes from the choice of the C++ project
that is "altera_nios_dev_board_cyclone_1c20.ptf".
The chip on the devboard is a EP1C12F324
Now I try to create the C++ project with the template "altera_nios_eval_board_cyclone_1c12.ptf".
but I can't go further than the creation wizard, I have this error :
!SUBENTRY 1 org.eclipse.core.resources 4 77 août 23, 2006 21:23:12.31
!MESSAGE I:/altera/kits/nios2/components/altera_nios_dev_board_cyclone_1c20/system/software/hello_world_0_syslib and I:/altera/kits/nios2/components overlap.
!ENTRY org.eclipse.cdt.ui 4 4 août 23, 2006 21:29:58.93
!MESSAGE Error
!STACK 1
org.eclipse.core.internal.resources.ResourceException: Invalid project description.
at org.eclipse.core.internal.resources.Project.checkDescription(Project.java:131)
at org.eclipse.core.internal.resources.Project.create(Project.java:220)
at org.eclipse.cdt.core.CCorePlugin.createCProject(CCorePlugin.java:550)
at com.altera.ide.core.project.NiosProjectCreator.createNewCProject(NiosProjectCrea
tor.java:107)
at com.altera.ide.core.project.NiosProjectCreator.createNiosProject(NiosProjectCrea
tor.java:67)
at com.altera.nj.ui.wizards.ManagedNJWizard.createDefaultSDKProject(ManagedNJWizard
.java:296)
at com.altera.nj.ui.wizards.ManagedNJWizard.doRun(ManagedNJWizard.java:250)
at org.eclipse.cdt.ui.wizards.NewCProjectWizard$1.run(NewCProjectWizard.java:213)
at org.eclipse.ui.actions.WorkspaceModifyDelegatingOperation.execute(WorkspaceModif
yDelegatingOperation.java:45)
at org.eclipse.ui.actions.WorkspaceModifyOperation$1.run(WorkspaceModifyOperation.java:71)
at org.eclipse.core.internal.resources.Workspace.run(Workspace.java:1595)
at org.eclipse.ui.actions.WorkspaceModifyOperation.run(WorkspaceModifyOperation.jav
a:85)
at org.eclipse.jface.operation.ModalContext.runInCurrentThread(ModalContext.java:30
2)
at org.eclipse.jface.operation.ModalContext.run(ModalContext.java:252)
at org.eclipse.jface.wizard.WizardDialog.run(WizardDialog.java:758)
at org.eclipse.cdt.ui.wizards.NewCProjectWizard.invokeRunnable(NewCProjectWizard.ja
va:231)
at org.eclipse.cdt.ui.wizards.NewCProjectWizard.performFinish(NewCProjectWizard.jav
a:154)
at com.altera.nj.ui.wizards.ManagedNJWizard.performFinish(ManagedNJWizard.java:233)
at org.eclipse.jface.wizard.WizardDialog.finishPressed(WizardDialog.java:608)
at org.eclipse.jface.wizard.WizardDialog.buttonPressed(WizardDialog.java:321)
at org.eclipse.jface.dialogs.Dialog$1.widgetSelected(Dialog.java:423)
at org.eclipse.swt.widgets.TypedListener.handleEvent(TypedListener.java:89)
at org.eclipse.swt.widgets.EventTable.sendEvent(EventTable.java:81)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:840)
at org.eclipse.swt.widgets.Display.runDeferredEvents(Display.java:2022)
at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java:1729)
at org.eclipse.jface.window.Window.runEventLoop(Window.java:583)
at org.eclipse.jface.window.Window.open(Window.java:563)
at org.eclipse.ui.internal.NewWizardShortcutAction.run(NewWizardShortcutAction.java
:96)
at org.eclipse.jface.action.Action.runWithEvent(Action.java:842)
at org.eclipse.jface.action.ActionContributionItem.handleWidgetSelection(ActionCont
ributionItem.java:456)
at org.eclipse.jface.action.ActionContributionItem.handleWidgetEvent(ActionContribu
tionItem.java:403)
at org.eclipse.jface.action.ActionContributionItem.access$0(ActionContributionItem.java:397)
at org.eclipse.jface.action.ActionContributionItem$ActionListener.handleEvent(ActionContributionItem.java:72)
at org.eclipse.ui.internal.Workbench.runEventLoop(Workbench.java:1402)
at org.eclipse.ui.internal.Workbench.run(Workbench.java:1385)
at org.eclipse.core.internal.boot.InternalBootLoader.run(InternalBootLoader.java:85
8)
at org.eclipse.core.boot.BootLoader.run(BootLoader.java:461)
at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method)
at sun.reflect.NativeMethodAccessorImpl.invoke(Unknown Source)
at sun.reflect.DelegatingMethodAccessorImpl.invoke(Unknown Source)
at java.lang.reflect.Method.invoke(Unknown Source)
at org.eclipse.core.launcher.Main.basicRun(Main.java:291)
at org.eclipse.core.launcher.Main.run(Main.java:747)
at org.eclipse.core.launcher.Main.main(Main.java:583)
!ENTRY org.eclipse.core.resources 4 77 août 23, 2006 21:29:58.93
!MESSAGE Invalid project description.
!SUBENTRY 1 org.eclipse.core.resources 0 0 août 23, 2006 21:29:58.93
!MESSAGE OK.
!SUBENTRY 1 org.eclipse.core.resources 4 77 août 23, 2006 21:29:58.93
!MESSAGE I:/altera/kits/nios2/components/altera_nios_eval_board_cyclone_1c12/system/software/hello_world_3_syslib and I:/altera/kits/nios2/components overlap.# #############################
Can anyone help me ?
Thanks a lot.
Best regards.
