20 years ago
Nios II Evaluation Board "not responding"
Hi guys, I am using the Nios II IDE to implement some C++ code that controls a VFD on a Nios II Evaluation Board. I've gotten it to work pretty well, it displays whatever I want. However, the FPGA seems to stop operating after 5 to 10 minutes in an infinite while loop. My code is as follows.
#include <stdio.h># include "system.h"# include "altera_avalon_pio_regs.h"# include "string.h"
void chr_wr(int code);
void put_txt(int x,int y,unsigned char *text,int textlen);
void set_position(int x,int y);
void disp_clear(void);
int read_data(void);
void write_data(int dat);
void write_cmd(int cmd);
void wait_ms(long time);
void brightness(int br); //0 for 100%, 1 for 75%, 2 for 50%, 3 for 25%.  Must be 2nd instruction after function_set.
void set_udf(int code,int *data);
void init_vfd(void);
void function_set(int bus_width); //1 for 8-bit, 0 for 4-bit.  Must be first instruction sent after power-on
void entry_mode_set(int inc_dec, int shift);  //1 for inc and 0 for dec, 1 for display shift and 0 for cursor shift
void display_on_off(int display, int cursor, int blinking);  //1 for on 0 for off
const int udf={{0x1f,0x11,0x11,0x11,0x11,0x11,0x1f,0x00},
             {0x00,0x0e,0x0a,0x0a,0x0a,0x0e,0x00,0x00},
             {0x00,0x00,0x04,0x04,0x04,0x00,0x00,0x00},
             {0x00,0x0e,0x0a,0x0a,0x0a,0x0e,0x00,0x00}};
int main()
    int i=0;
    printf("VFD Controller Test - Remotec\n");
    init_vfd();
    put_txt(4,0,"Jason Kientz",12);      // text
    put_txt(5,1,"= Ballsack",10);
    //put_txt(0,0,"ABCDEFGHIJKLMNOPQRSTUVWXYZ0123456789-_=+",40);
    //put_txt(0,1,"abcdefghijklmnopqrstuvwxyz!@#$%^&*() <>.",40);
    set_position(0,0);write_data(0x01);    // udf 0x01 in each corner
    set_position(0,1);write_data(0x01);
    set_position(19,0);write_data(0x01);
    set_position(19,1);write_data(0x01);
    while(1)           // cycle udf&#39;s
        set_udf(0x01,&udf);
        wait_ms(100);
        i++;
        if (i==4)
            i=0;
    //write_cmd(0x3FF);
    return 0;
/* Function descriptions :-        */
/* init_h8         - Sets up H8 port directions                                                  */
/* chr_wr        - Places a single char at the current ddram location                            */
/* put_txt         - Writes a text string starting at col x,row y                                */
/* set_position        - Sets ddram location (cursor position) to x,y                            */
/* disp_clear        - Clears screen                                                             */
/* read_data         - Reads data from the module (at current position)                          */
/* write_data        - Sends a data byte (CD low)                                                */
/* write_8bit_data       - Sends a data byte with only 1 &#39;e&#39; strobe (CD low)                     */
/* write_cmd         - Sends a command byte (CD high)                                            */
/* write_8bit_cmd      - Sends a command byte with only 1 &#39;e&#39; strobe (CD high)                   */
/* wait_ms         - Waits for specified number of milliseconds                                  */
/* brightness        - Sets the specified brightness (0-3)                                       */
/* set_udf         - Loads data into a single udf char                                           */
/* init_vfd        - Initialise VFD                                                              */
    write_data(code);
int a;
    set_position(x,y);
    for(a=0;a<textlen;a++)
        chr_wr(text);         /* write text a character at a time */
    write_cmd(0x80+x+0x40*y);
    write_cmd(0x01);
    wait_ms(30);
int read_data(void)// MAY NOT WORK - CHECK ON HOW TO WORK WITH BIDIR PINS
  int result;
    write_cmd(0x300);
    IOWR_ALTERA_AVALON_PIO_DATA(LCD_E_PIO_BASE, 1);
    result=IORD_ALTERA_AVALON_PIO_DATA(LCD_E_PIO_BASE);
    IOWR_ALTERA_AVALON_PIO_DATA(LCD_E_PIO_BASE, 0);
    write_cmd(0x00);
    return(result);
    dat += 0x200;
    IOWR_ALTERA_AVALON_PIO_DATA(LCD_PIO_BASE, dat);
    IOWR_ALTERA_AVALON_PIO_DATA(LED_PIO_BASE, dat);
    wait_ms(1);
    IOWR_ALTERA_AVALON_PIO_DATA(LCD_PIO_BASE, cmd);
    IOWR_ALTERA_AVALON_PIO_DATA(LED_PIO_BASE, cmd);
    wait_ms(1);
    usleep(time*1000);
//0 for 100% brightness, 1 for 75%, 2 for 50%, 3 for 25%
  int value = 0x200;
  if (br == 1) value += 0x01;
  else if (br == 2) value += 0x02;
  else if (br == 3) value += 0x03;
  write_cmd(value);
int a;
    write_cmd(0x40+code*8);
    for(a=0;a<8;a++)
        write_data(data);
void init_vfd(void)
    function_set(1);
    wait_ms(10);
    brightness(0);
    entry_mode_set(1,0);
    display_on_off(1,0,0);
    disp_clear();
  int value = 0x20;
  if (bus_width == 1) value += 0x10;
  write_cmd(value);
  int value = 0x04;
  if (inc_dec == 1) value += 0x02;
  if (shift == 1) value += 0x01;
  write_cmd(value);
  int value = 0x08;
  if (display == 1) value += 0x04;
  if (cursor == 1) value += 0x02;
  if (blinking == 1) value += 0x01;
  write_cmd(value);
/* *****************    12.Pin Assignment                     ************** */
/* *****************      12.1 Signal Connector.              ************** */
/* (parallel# 1 )       12.1  CU20025ECPB-U1J  Signal Connector              */
/*    Pin      Signal                Pin      Signal                         */
/*    1        GND                   2        VCC                            */
/*    3        FNC                   4        RS (P66)                       */
/*    5        RW  (P65)             6        E (P64)                        */
/*    7        D0                    8        D1                             */
/*    9        D2                    10       D3                             */
/*    11       D4  (P60)             12       D5 (P61)                       */
/*    13       D6  (P62)             14       D7 (P63)                       */
/*   Note : 4 bit mode                                                       */
Has anyone else ever had a problem like this. It has something to do with the FPGA not responding because if I try to download the software onto the board again before it locks up it works fine, but if I try to download the software onto the board after it locks up it gives me the following message
Using cable "Nios II Evaluation Board ", device 1, instance 0x00
Pausing target processor: not responding.
Resetting and trying again: FAILED
Leaving target processor paused
Im wondering if I have some sort of setting wrong or if I have some kind of memory leak. Im not sure. Any help would be appreciated.
Sean
    In my experience, and this isn&#39;t conclusive.. but when the programmer tries to reset the programmer and it fails the first time, it&#39;s likely a hardware issue, not software. As in the avalon bus is locked up.. if it&#39;s stuck in a loop or something, it can usually reset it the first time. What hardware components do you have in your system.
    --- Quote Start ---
    originally posted by jdhar@Apr 11 2006, 01:07 PM
    in my experience, and this isn&#39;t conclusive.. but when the programmer tries to reset the programmer and it fails the first time, it&#39;s likely a hardware issue, not software. as in the avalon bus is locked up.. if it&#39;s stuck in a loop or something, it can usually reset it the first time. what hardware components do you have in your system.
    <div align='right'><{post_snapback}> (index.php?act=findpost&pid=14258)
    --- quote end ---
    --- Quote End ---
    The heart is the nios ii eval kit (http://www.altera.com/products/devkits/altera/kit-nios_eval_1c12.html). Connected to an external powersupply (5v with gnd tied to the FPGA gnd) and 11 ouput pins is a noritake itron cu20025ecpb-w1j vfd (http://www.noritake-itron.com/subpages/productse/vfmodlcdcomp.htm). There is now also a 4 button keypad (http://www.storm-interface.com/dyncat.cfm?catid=19030) and an a/d (http://focus.ti.com/docs/prod/folders/print/ads7824.html) connected but this problem was occuring when just the VFD was connected. The VFD, keypad, and A/D all work properly while the FPGA is functional.
    Sean
    Since you are using the IDE, have you tried debugging and seeing where the processor is when it goes into it&#39;s loop?
    Just check if you have evaluation version of Nios core. This has restrictions
